Water Leak
Started by scoobster, October 15, 2004, 04:59:36 PM
scoobster
I had to leave the car out of the garage for the past couple of days and we have had some heavy rain and i have found the passenger side rear carpets are wet:( :( :(
Are any of the door or sunroof seals known to fail? or has anyone else had this problem?
:cheers
gsb876
Although not had this particular prob myself, have heard of it happening to other rx\'s though!!!:(
leggysrx7
..i think i may have the same problem, though if i park the car with the nose facing up the driveway then there doesn\'t seem to be a problem...reverse the car up the drive and i reckon that\'s when the problem occurs..
....next Saturday i reckon i\'ll be in the boot, as a mate hoses the car down try to find the problem ;)
Open to suggestions/solutions.
Marc
Ricco_04
I also noticed that if I park mine with the nose facing downhill that water seems to collect in the boot (but must just run out when parked uphill).  Could it be that it comes in the same way but manages to run into the back of the car rather than the boot?
