Displaying speed on commander
Started by ScuttleRX, October 22, 2004, 06:18:34 PM
ScuttleRX
When selected in monitor mode no speed registers on the commander, do I have to buy something extra to get this to work or is it likely a wiring issue
iaint
Doesn\'t work on mine either so I suspect it\'s a feature!  Would be interested in the answer to this too.
Iain
Ed_RX7
are you sure you have the right commander for the pfc that you have .....mine works fine!
:confused:
Edrx7Parts
07531 669 768
Also of
ScuttleRX
yeah its right one, have been running it for ages now, everything else works as it should, just no speed reading.
Just wondering whether theres a sensor or something that needs wiring up, have been meaning to ask this question for nearly a year now :D
maximtaylor
I suspect it could be a cheap trick to remove the 112 mph speed limiter - cut speed signal to ecu, no limiter! left wired to speedo only.
Blame the people you bought your cars from ;)
Mine works :) na, na, nana, na!
Max
ScuttleRX
:D no-one likes a smug bugger!  speedos reading mph, etc and my odometers in miles so i think they must have done it properly?
ScuttleRX
maximtaylor
Speedo converting to mph from kmh and removing the limiter are two separate issues unfortunately :(
It seems too much of a coincidence that everything else works!
I suspect the wire has been snipped very close to the ecu.
xxx
Smug bugger
ScuttleRX
ahh gotcha, I was under the impression it was an all in one type thing.
yeah sounds like it is that then, take it i wont be restricted again if I wire it back up ?:D
maximtaylor
You\'ll be fine, the Apexi doesn\'t limit speed. Only the stock ecu does.
Can\'t help with the colour of the speed signal wire though :(
Go have a rummage in yer passenger footwell ;)
Max
ScuttleRX
I\'ll see what I can find, hopefully everything will still be working when ive finished :D
