2 Problems
Started by rmagictastic, October 13, 2004, 08:49:42 AM
rmagictastic
hi,
 wondered if anyone could help with a couple of problems ive got,
1/ my headlights go up when i turn them on, but dont go down when i turn them off, anyone got a 94 wiring diagram, i got a 93 but its not the same as my car. ??????
2/Gearbox, rattling noise when clutch pedal up(engaged), but no noise when down. and recently(yesterday) when i have the car at a stop and in gear, the clutch to the floor, the car still bites and eventually stalls, this only happens once warmed up, it appears,???
any ideas would be great,
Getting old... Its not like it was in my day!
MillSpeed
Not sure about the lights, but the rattling noise when the clutch is engaged sounds like the thrust bearing. Mine\'s whirring like a bastard, but it\'s not rattling yet. As for the clutch engaging while the pedal\'s down to the floor, that sounds like you either have a clutch fluid leak somewhere (perhaps the diaphragm in the slave or master cylinder has failed) and/or air in the system. Have a look for evidence of clutch fluid about the place and try bleeding the system.
Matt.Wild
Does your button on the dash that opens the lights work?  If not, when it is disconnected, the lights raise but do not drop.
You\'ll need to take off all the screws from the dash, lean the whole thing forward and make certain the plug going into the back of the light pop up button is fully pushed in.
I found this out by turning the lights on without it connected.  They would raise, but not drop.
HTH
