Front Side Lights
Started by Steve Burnett, May 18, 2003, 03:11:34 PM
Steve Burnett
Hi there,
Im wondering how best to clean up my front side lights. Im a bit reluctant to remove then as I think they are sealed on?? Is it best just to remove & clean or what?
Any ideas would be great.
Steve
j9fd3s
the 1st and second gen cars lights arent sealed at all.  the 3rd are, they will come off as a whole assembly
mike
Steve Burnett
Its a 3rd gen I have.
How do you mean taking out the whole assy.?
I thought I would have to just remove the screw at the side of each light, the clean it. Obviously this would mean breaking the seal. Any ideas?
Steve, do you mean cleaning the inside of the lense? If you are then yes I think you will have to crack open the lights.
I think they are only held with a sticky foam pad type stuff.
Dan
Hi Steve ,
l removed mine when l first brought the car and they were dirty and misted up , l poured washing up liquid in them and rinsed under a hot tap then left them to dry on a radiator indoors for a day , been fine since.
Hope this helps
clive@mazdarotaryclub.com
//www.mazdarotaryclub.com
Steve Burnett
Did you remove the whole unit and do that or just removed the glass?
If it was just the glass you removed how did you re-attache them to the car, inc. the seal?
QuoteOriginally posted by Steve Burnett
Hi Steve ,
l removed the whole unit then filled it up through the bulb holder and shook it around then rinsed thoughly.
