Performance of F3DS
Started by Holmsey24, October 05, 2004, 11:49:20 AM
Rixio
#15
mines only 2" off the front bumper so it catches everywhere if going at speed even on normal roads without bumps but if u go diaganol across them then its fine
the real problem is backing it up the drive...2 of my cars catch on it cos its a hill btm drive:(  iv noticed 2 new craks on the bumper since it got taxd that wernt there b4 so best thing is pump up ur tyre pressure so u got more clearance lol:cool
gsb876
Yep its one problem with these cars, i have to reverse at a diagonal angle to get the car onto the drive!!!!
Which is why the cars always parked at an angle on the drive!!!:(
scooby_si
STICK eagle F1\'s on straight away IMO i had a set in my bedroom i put off sticking on as i was guna kill the rice rubber at silverstone accept it didnt quite get to that stage http://www.smileycentral.com/?partner=ZSzeb008\' target=\'_blank\'>http://smileys.smileycentral.com/cat/10/10_12_7.gif\' border=0> soooooo not worth waiting!!!!
Also get a track or air strip day lined up soooo cunning to learn limits in safety
All IMO having learnt the hard way but like the RX8 should come with a learning track day as standard IMO.... http://www.smileycentral.com/?partner=ZSzeb008\' target=\'_blank\'>http://smileys.smileycentral.com/cat/18/18_5_1.gif\' border=0>
Si (jokes about being cr4p behind wheel loose appeal when yer heading wrong way to sumin solid......)
Rixio
G dawwg havnt u eva been pulld for that front num plate b4??
gsb876
Not yet , touches wood!!!!
I think they leave me alone as the plates clearly visible and easily readable too:)
Holmsey24
Car looks sweet Gurj.  I like those headlight conversions. :cool
Top_gear_towers
Deffo change the japanese rubber.
I had some japanese rubber on my NA MR2 a few years back.
Never heard of the make of tyre, but went cheap on myself and kept putting it off.
Two weeks later, in torrential rain around October time on a country road the car just pendulums out on a slight corner at about 50mph. Even when I corrected it, the car settled centre for only a moment, then swung out again.
I finally slid to a rest with a tree trunk inches off the front, and another a metre from the rear...I had slid between the two trees!
£4,000 later - and some new Goodyear F1\'s, car was fine. When I later upgraded to a MR2 Turbo pushing out 300bhp - F1\'s still kept it planted in the wet.
Amusingly low resolution pictures from my camera phone (it was three years ago!)
Rowly
Top_gear_towers
Here\'s another one :)
Holmsey24
Think you had your lottery win luck that day!!!
Will bear your story in mind when I take delivery!!!!
