the most eco rex about
Started by yonner, September 13, 2004, 05:56:38 PM
yonner
ok so i flooded the car again :reallymad took the plugs and fuel relay out 3x5sec bursts to clear her out plugs back in map sensor conedted up fine but for got to put the fuel relay back in and she started 1st turn and ideld perfec for a few minuts then i shut her off and when i relised i had left it out i put it back in tryd to start and the fuel pump wont fire up any ideas???
when your life is a mess light one more ciggaret its so logical!
bobster
Check the fuse for the fuel pump it can be found in the drivers footwell in the fuse box it\'s one fo the 20A fuses in case your japanese is rusty :D
rx7aberdeen
to save all the fannying about 3/4 a can of coke straight into the inlet manifold saves all the hassle of removing the spark plugs and it works did it myself
yonner
u serious coz im gullable enuf to try that
jonrx7uk
Yeah, tell us more!!!!
rx7aberdeen
trust me!!  The car was in the bodyshop getting the kit fitted and they flooded my engine!  was prepared to remove the plugs and everything, phoned the guy i bought the car from and he told me to remove a pipe from the inlet manifold and pour three quarters of a can in and turn the motor over and to my surprise it turned over!!!  has to be coke not diet and once it has started let it idle and smell the smell of burning coke.  The rx7 is the only car this technique works on!
I can see some of the logic behind it (a strong detergent that\'ll remove oil, etc), but I\'ve not found anything on the internet to suggest that as a normal course of action.  Rx7aberdeen, you gonna have to confirm this works....
Brett
This info has been posted B4, ask Si, I think he used the method, or at least provided the smilies to go with it!
Brap Brap Brap Brap
jonrx7uk
Thats the craziest thing i\'ve ever heard, but it might just work....:p
moakesr
The sugar must have something to do with it if diet coke doesn\'t work.
...or we are all victims of a huge joke :D
Richard
scooby_si
i didn\'t actually try it in the end mainly cause it was fun watching the mechanics i was with attempt to reach the plugs over & over again....lol
& i just didnt fancy it not to say it doesn\'t work but anything which can clean toilets so well (seriously flat coke kicks ass at cleaning stuff) i figured maynot be seal friendly....only a guess thou although i wouldn\'t use diet as it may mean you run lean :rollin  sorry i\'ll get me coat (that last lean bit was a joke BTW ;))
Si
Donato
What you really have to ask yourself is...
The guy who discovered this....
What exactly was he on at the time? :D
