intake/intercooler temps?
Started by scooby_si, September 03, 2004, 12:29:15 PM
gsb876
bnaellis
To see how hard the injectors are working to supply fuel. basically 100% duty cycle they are working flat out. Apparently the atomisation is better at higher duty cycle above 80% but you don\'t really want it for reliability reasons above 80-85%.
rgds
scooby_si
well spent the whole day mullering my skinny arms http://www.smileycentral.com/?partner=ZSzeb008\' target=\'_blank\'>http://smileys.smileycentral.com/cat/10/10_10_3.gif\' border=0> getting a cold air feed into the normal intercooler feeding bit & it is noticably better certainly at cooling down while driving but still realistically way too high & still goes into the high 60\'s if a large chunk of boost is attempted.......
Looks like silverstone is a definate no go at least from a track point of view but will still be driving there & all that.....
Hopefulyl the vented bonnet will assist more when that\'s on but even that aisde time for the bumper to come off again & get some modifying done to that so they get normal airflow......
Anyone had this problem with any aftermarket bumpers before?
Si (better than was but far from perfect.....)
gsb876
Thanks Brian,
an important bit of info there:)
scooby_si
out of interest where is the "air temp" for the power FC actually taken from then?
Si http://www.smileycentral.com/?partner=ZSzeb008\' target=\'_blank\'>http://smileys.smileycentral.com/cat/15/15_6_4.gif\' border=0>
The air temp sensor is on the under side of the UIM.
scooby_si
stupid hat on what\'s the UIM you know i\'m not very good with these shortening things roflmaoshins......
Si
maximtaylor
Upper inlet manifold - commonly know as the plenum. If you stick your hand underneath from the bulkhead side (back), you\'ll feel a sensor going up into it. This is the one :)
Max
