Water Temp and Oil Temp ??
Started by Peter10654, August 24, 2004, 12:13:24 PM
Peter10654
Hi Guys..
I\'m from Germany and my english isn\'t so good. Sorry for spelling mistakes.
I have a problem with my 95\' FD. It\'s a import from Japan.
Retrofitted Koyo Cooler with High Volume Blower, another Thermostate, Apexi Power FC with Commander, Downpipe, Midpipe and Blitz Nür Spec R Exhaust, Oil Temp...
Performance is very good but i have heavy Temperature Problems.
But for all that changes with cooler and blower... the temperatur is very high. With 120km/h the Temp is OK with Water 88°C but if i drive with 160km/h - 180km/h, water have 96 - 100°C. Faster than 160km/h (hold on 180km/h to 200km/h) the Temperatur goes to Water 110°C -120°C (cooking) and Oil Temp to 120°C.
Andybody in the Forum have an idea ?? Waterpump ??
I have no more Ideas ??
Please help if anybody had the same Problem...
Many thx and hoping for help.
Peter
Or a good car garage near the most southern point in GB so i can bring my car to GB ??
gsb876
That does sound quite high temps there.
Should be around 80-90oC for water temp.
And 70-85oC oil temp.
I suggest you get the car cooling system checked out and check that the intercooler / oil cooler is not being odstructed from the front of the car? EG - If the plate number is blocking any of those??
