Borgwarner s366
Started by Grant Monkhouse, May 15, 2021, 11:42:41 AM
Grant Monkhouse
S366 turbo, never been used. £650.
Comes with 2 turbine housings. One divided entry T4 1.00AR the other a single entry T4 0.88 AR. The 0.88 has a hole drilled in it to weld and mount a Wastegate directly  too it.
Comes with all v band for inlets and outlets.
3 inch mishimoto v and and clamp for compressor outlet
3 inch vband on the 0.88 turbine housing with clamp and also piece of 3 inch stainless as new Trubo requires 4 inch down pipe
3 inch v band and clamp for the 1.00AR housing this is a Mormon flange. Think they usually 50 quid on there own.
Also comes with an extra 3 inch mishimoto v band and clamp assembly, again surplus to requirements as its not big enough
Sent from my VOG-L09 using Tapatalk
