mikey t needs more space and money oem clearout
Started by mikey-t, December 27, 2014, 09:38:34 PM
mikey-t
right then, this is all ready to go as i need the space / money for newer parts.
all parts are advertised as collected as time is of a premium to me, postage can be arranged but at extra cost and maybe a little delay.
the bigger stuff i will have to insist on being collected.
got a drivers door and boot, not immaculate by any stretch but both solid and the glass is not cracked. door is as seen, includes mirror and trims, boot had a dodgy de spoiler job done which has bubbled up, the glass seal has all been cut out its purely silicone holding it in so probably sold just for the glass
got to be £50 for the both
powdercoated LIM , crossover pipe and y pipe from standard twins
£30
flywheel,
its supposedly a lightened unit, i didnt use it as there was no locating dowels or holes for them so buyers risk with this
£30 probably get that in scrap value
reflectors
£10
random pulley
£5
mikey-t
coils, i have all 4 somewhere but can only find the 3 at the moment, no doubt it wil lturn up,
they where working when i pulled them off so sold as seen test if you want, £40 for the 3 £55 for all 4 if i find them
fan control relays etc
£20
apexi EL boost gauge and controller
cut off at the power lines which isnt a problem as they are only spliced in anyway , working just fine when removed,all connectors and sensors there
£40
front bumper skin, scratched, crazed and bent to (censored) but ideal for the drifters / racers out there that will just drag it across armco anyway
£30
interior sections, boot sides, handbrake console,boot back, all scuffed and bits bent or screw holes damaged, but can quite easily be fitted and used in a daily and not get noticed
£20 each £10 for smaller bits
mikey-t
front bumper inner crash bar, all in one piece, a little fracture here and there but all good.
£30
random vac hoses, fill a ziplock bag for £3 each
fuel lever,bonnet pop fascia thing
hillbilly compression pipe made by someone at some point, covered in heat tape . 3 holes drilled in it in random places. can weld up or tap a thread in for you and you can bung it
£40
few an-6 fittings y piece, 15' 90' etc all torques. hose finnishers. thread to push fit etc block off screws, plates, o2 bung,  etc etc etc
iduvidually priced or bulk deal bulk deal £40
mikey-t
mikey-t
buy me! i only have one connector broken and thats easy enough to splice into i would have thought. unused, therefore untested.
some serious money in parts alone
boosted
mikey-t
With it being damaged and untested I would say £200 is fair, it's the connector that fits behind the water filler that broke.
I say £200 as I had to import all the connectors, and there is a lot of wire, heat shield, braiding.
Without labour there is £300 there
