Idle Control Valve - can it run without?
Started by imebgo, May 16, 2014, 09:01:32 AM
imebgo
Can a car run without the idle control valve?  Its located on the plenum of a 13b, and located on the throttle body of the 20b, so I want to use the 13b throttle body (as its right hand drive!)
This would mean the idle control valve is missing, can the base idle be held without it?  I know air con would affect the idle, but this has been removed.
Thanks,
James
leeroy_25
Hi James,
Think I may have given you an answer already but in case not and for anyone else\'s benefit.
Should be fine.
I ran my old 13B without this permanently. Just requires base idle to me manually adjusted a little bit higher for when it goes on load with a/c etc.
imebgo
Cheers Lee,
Nice to know, however I will probably be running it anyway :)
/J
