Water Temp sensor
Started by warrendj2000, September 13, 2004, 01:58:41 PM
warrendj2000
Please Help, My PFC Commander is flagging up that the Water Temp sensor is not working. Where is this sensor located in the engine bay ?
Cheers,
Dave.
MillSpeed
I believe it\'s on the back of the coolant filler neck, on the opposite side to the coolant level sensor. I\'ll see if I can get a piccy, can\'t remember for sure.
MillSpeed
Ah shit, can\'t see it. The upper boost pipe is right slap-bang in the way. I\'m sure it\'s down there underneath the pipe, on the rear of the waterpump housing.
warrendj2000
Thanks for looking MillSpeed, Can anyone else help ?
antnicuk
As above, it is there, just below and behind the alternaor bracket,  check that the connector is plugged in.
