Leak after rebuild
Started by Palmeruk, October 22, 2013, 07:08:18 PM
HaywardRotary
Quote from: TRIND-FD;866534That\'s open too debate. Hence they don\'t last without one :)
Hey Keith, I have two t88\'s out there that have done loads of miles and been running for over 5 years running bridge ports and making some decent power that aren\'t running restrictors, they are a plain bearing turbo.
Its only ball bearing turbos that need restrictors.
There is something else wrong in this case. it could even be a poor draining issue.
Single turbo conversions.
S
HaywardRotary
Quote from: Palmeruk;866523Ok so i can saflely say the oil seals have gone? Looked at rebuild kits, are they east?
I would have a thorough investigate first.
S
colum
what size is the oil return line on the turbo?
TRIND-FD
Quote from: HaywardRotary;866556Hey Keith, I have two t88\'s out there that have done loads of miles and been running for over 5 years running bridge ports and making some decent power that aren\'t running restrictors, they are a plain bearing turbo.
I don\'t dispute that Carl, and like you say oil return can cause the issue.  Garret themselves say that it\'s not generally needed, but may be needed depending on oil pressure. .  As rotary engines have 100psi plus oil pressure they can blow oil past without a restrictor.  Like I said open to debate.
V8 fd\'s rock :cool
Palmeruk
Quote from: colum;866558what size is the oil return line on the turbo?
its the same diameter as the return feed, no down sizing etc, have rebuilt the turbo and its still weeing out, not quite sure where to go from here
mite be worth sending it off, does anyone have any recommendations on company\'s?
Dragun
CRturbo engineering....brilliant company, rebuilt and balanced my t78 perfectly.
[SIGPIC][/SIGPIC]
Rotary Massacre
   Dare To Be Different...
Arnie_O
May sound silly but have you made sure your breather pipes are not blocked (the ones off your oil filler neck ?
Turbocharged 192ps RX-8 running Meth Injection on an Adaptronic
Fully Bridgeported 231ps RX-8 stripped for the Track
2nd Gen RX-7 TurboII on a GT35r (show winner)
