Fitting Re-Am short shift on FD
Started by LOLRich, January 06, 2014, 09:39:31 AM
LOLRich
Hoping I\'m not the first to have a fail on this...
Replacing my Ikeya sequential with a re-am short shift, I have two issues, which may be related...
1. The brass cup that comes with it does not stay on, in the same way that the plastic ones do, I assumed that was normal?
2. The shifter slips out of the mounting cup on the gear change when I try to shift through the gears, it\'s almost like it\'s too short to seat firmly in the cup?
Anyone had this problem?
Rich
Arnie_O
The brass cup/cooler is meant to be separate.
Have you bolted it down before trying to test it?
Turbocharged 192ps RX-8 running Meth Injection on an Adaptronic
Fully Bridgeported 231ps RX-8 stripped for the Track
2nd Gen RX-7 TurboII on a GT35r (show winner)
LOLRich
Yup, all bolted down, rubber cowls on.. and it just seemed to pull out of the cup...
TRIND-FD
Sounds like you need the bigger collar.
V8 fd\'s rock :cool
LOLRich
Hmm the old gear shift has the same issue though? Doesn\'t make sense...
TRIND-FD
Quote from: LOLRich;871051Hmm the old gear shift has the same issue though? Doesn\'t make sense...
Guess you broke it then ?   Got a spare here if you want. Good price.
V8 fd\'s rock :cool
LOLRich
Quote from: TRIND-FD;871355Guess you broke it then ?   Got a spare here if you want. Good price.
Spare what, gear box?
TRIND-FD
Quote from: LOLRich;871423Spare what, gear box?
Yep :).........
V8 fd\'s rock :cool
