Help roof problems
Started by rossco, January 01, 2014, 11:28:37 AM
rossco
Could some one help, just gone to put roof down turned the switch it beep a few times and then one long beep and nothing happens.:3Confused
It's all good
johnf
Can\'t think of anything other than the obvious
You\'re not hung over from the festivities and fogrotten to undo the latches?
And why do you want the roof down - it\'s January.............................
rossco
Not hung over lol did the latches.just giving it a good clean and check over
It's all good
kev-yorks
The hand brake is applied I take it and the switch working?
Barring that if its just a sticky motor or the like putting it into manual override and opening a few times has worked for me in the past.
Regards Kevin
rossco
Hand brake that\'s the one thank you.
It's all good
