Vacuum hoses. Which and where?
Started by The dutchman, November 21, 2013, 10:05:41 PM
The dutchman
Hi guys.
This winter i want to replace my vacuum system on my stock \'92 touring.
Searched allot on the internet and found some different stories....
Most say take silicon hoses.
First which size hoses do i need? Some say 4 and 6mm. But some other kits in the usa contains 7 different sizes....
And what kind of lenght?
And where can i get some good hoses in this area? Most kits come from the usa.... And most of the silicon vacuum hoses i can find here have a wall thickniss of 2mm. That seem\'s a little thin...
Do any off you have experiences with Samco vacuum hoses? A good brand. But are they any good?
And the 6mm hose seems to be 6.3mm on the samco. I don\'t now if that\'s a problem?
Thanks.
exiled-viking
you could get in touch with these guys they are really friendly if they cannot help you they do try to put you in touch with some one that can, I have had their hoses on my 8 for the last 6 years and there very good but can cost.
http://www.viperperformance.co.uk its worth a call
The dutchman
Thanks for the tip! But i allready had a look on the site and they dont have 6mm....
And on the 4mm the wall is just 2mm i dont now if that\'s enough.?
exiled-viking
For a price they can make what you like they did for me so as I said its worth a call
Arnie_O
Generally the wall thickness is sufficient to withstand vacuum, for that perticularly diamiter hose.
I have rev aced a couple of FD\'s now and from memory I used mainly 3mm to ensure a tight seal and a small amount of 5mm too.
Turbocharged 192ps RX-8 running Meth Injection on an Adaptronic
Fully Bridgeported 231ps RX-8 stripped for the Track
2nd Gen RX-7 TurboII on a GT35r (show winner)
Try and go for Viton lined hoses as the oil that tends to pass around will attack normal silicon in time.
You need manly 3mm inside diameter and some 6mm inside diameter.
Little tip,
You will find all the pipes connected to plastic solenoids etc, very very brittle, so use a hobby knife to slit all the old pipes off and you small cable ties to stop your new hoses popping off
The dutchman
Thanks for the tip Clive. Will keep it in mind for sure. :Thumbs-up
I saw a few more posts about Viton. But are quite expensive.
But are silicon hoses tben no good?  Because i see them on many rx\'s.
Arnie: will the 3 and 5 mm fit good?
