Counter weight?
Started by Palmeruk, September 30, 2013, 09:16:30 PM
Palmeruk
Just bought a twin plate clutch, what type of counterweight do i need? Bit confused
You will need the Mazda Auto counter weight that is specific to your engine, i.e. FD FC FE
Palmeruk
Brill thank you :-) whats the difference between the auto and non auto?
Your manual engine will have not have a counterballence weight to bolt your new flywheel onto,
Once your flywheel is removed you will find you have nowhere to fit the six bolts that will hold you new flywheel to the engine
All aftermarket flywheels, no matter what the make need somthing to bolt onto which is why you need an Auto weight
hope this helps
