Rear view mirror with camera and sat nav
Started by Kamatari, July 08, 2013, 12:33:05 PM
Kamatari
This is a rear view mirror that has a 5inch touch screen panel, has sat nav installed and also has a recording camera with "night vision" that works nicely. It comes with a bluetooth headset which charges on the side of the unit.
The touch screen panel runs windows ce which you can access, you should be able to attach a little bluetooth adapter to the unit and then run a windows ce OBD software and use it as a little hud for your car :) (you will need a bluetooth obd adapter though which is only about £9 on ebay)
I\'m after £100 delivered :)
RexMidlands - A place for Midland rotary owners to hang out
Timmyc
Pretty cool, how does it attatch to the window?
Kamatari
