FD Clutch Change
Started by Metalorama, July 08, 2013, 12:58:56 PM
Metalorama
Well the pressure plate gave up on my clutch recently, as I thought it might, it was more a track clutch anyway and I hated it! Bit the bullet and bought an ACT organic clutch kit which comes with the pressure plate, clutch, release bearing, pilot bearing and alignment tool.
I was wondering if there are any other bearings or parts I should replace since I\'ll be in there anyway. Also I believe the current clutch has a push/pull converter is it right to assume that\'ll be good for using on the new clutch? Total noob to clutches so any help is appreciated.
Cheers.
