window fault
Started by woolley bully, October 02, 2011, 11:31:43 PM
woolley bully
hey all ..my windows are playing up ,, they work fine most the time an just when im about to park up not a thing,, no up or down on both windows an then after a wile i go back 2 the car an try them an there working again ..seems to be more offen now theat they dont work so im going all over the place with the windows up in case i cant get the windows back up again ,,,any ideas ??   i was thinking re-lay or switch ...on the subject of relay where is the window relay ?? cheers all in advance
jimbo_GR
did you get this sorted? if so what did you find was the problem ?
wolfie1
Fair chance the f110 box is faulty on some cars is an f100
woolley bully
Sorry for the long delay in my reply ,, yeah got it sorted ,, it was the plug where it go\'s from the door into the wing ,, the clips had broken off the connector an was slightley lose , gave it a push an works like new :)
woolley bully
Forgot to say , once in a blue moon the window stops working an I just give the connector in the wing/door join a push an all works fine again
