Ignition barrel help
Started by nadz, November 01, 2012, 07:37:22 PM
nadz
I\'m not sure what the issue is but when I put the key into ignition it\'s hard to twist the key I have to play around wiggling the key for 5-10 mins for it to actually twist. Any help on this guys on what I can do??
TRIND-FD
Quote from: nadz;839988I\'m not sure what the issue is but when I put the key into ignition it\'s hard to twist the key I have to play around wiggling the key for 5-10 mins for it to actually twist. Any help on this guys on what I can do??
Buy a new one :).  Think Martin @ Speedline has a full lock set cheap
V8 fd\'s rock :cool
nadz
Quote from: TRIND-FD;840007Buy a new one :).  Think Martin @ Speedline has a full lock set cheap
I think I\'ll have to.
rx-dave
Have you tried a few squirts of WD40, usually works well, if it\'s badly worn then you\'ll need a replacement :2Mad
nadz
Quote from: rx-dave;840011Have you tried a few squirts of WD40, usually works well, if it\'s badly worn then you\'ll need a replacement :2Mad
I tried wd40 today but hasn\'t worked might try more in the morning. As its my daily I need it to work.
Eoiny555
I had the same problem before with ignition & door lock, a good spray of wd 40 & let it sit for a bit then give it a good few turns & it freed it up for me
