little help required...
Started by juniorbamf, October 02, 2012, 02:31:55 PM
juniorbamf
does anybody know if you can remove this lower part of the gear stick, or if its possible??
is there a special tool required for the job or should i just use all my force to unscrew it.
thanks.
Speedline Imports
The shifter is bolted in.  Remove the big rubber boot (4 x 10mm bolts)  then you will see the 3 x 10mm bolts that hold the shifter into the box.
martin@speedlineimports.co.uk
TEL. 07742 690672
Monday-Friday 9am-5pm
Speedline on Facebook
Brett
Brap Brap Brap Brap
Undo the rubber cover and you will see :) im actually amazed it still has the cover lol
What is the reason you are removing the short shifter anyway? You going back to OEM?
juniorbamf
sorry i just meant the chrome bit, only want to know if that bit can be removed, not the entire thing from the box.
Brett
Sadly not, it\'s a complete assembly.
Brap Brap Brap Brap
juniorbamf
ah i see,
would it be possible to get a different shifter that fits in place?
Brett
There are various kits available - it depends on what you are trying to achieve?
Brap Brap Brap Brap
juniorbamf
well i literally just want the bulky chrome bit out of the way really so that the gear knob will be lower down when fitted.
What you have there looks like a short shifter anyway as the OEM ones are black, that looks IDENTICAL to my short shifter:
Here it is fitted in my MX5 (they can fit in both)
It easily comes out - there will be a spacer on top of the OEM box which makes it a short shifter
Why do you want to remove it though? The gear gaiter goes over it, remove the rubber surround and take a photo of it, the short shifter does unscrew in 2 parts at the base:
juniorbamf
ahhh thanks mitch, sorry i missed your comment earlier aswell.
ill get another photo tomorrow and see how it goes. cheers.
Quote from: juniorbamf;837281ahhh thanks mitch, sorry i missed your comment earlier aswell.
Yeah just take some photos, the OEM gearstick is quite thin and is black, you will see if its the same as mine when you take off the rubber cover - also if you do take the actual gear lever out be careful of the mucky oil in there as you might be able to see on my photos lol
Brett
....don\'t think it\'s black in the EGi\'s?
Brap Brap Brap Brap
juniorbamf
yer mines a tad different out of my egi -
