Gear knob
Started by Jot17, August 03, 2012, 12:12:20 AM
Jot17
Hi,
Hey guys I know this is a stupid question but just wanted to ask will this gear knob fit on my fd, I don\'t know if I\'ve posted this in the wrong area if I have I\'m sorry. I\'m new to all this so forgive me lol:):)
http://www.demon-tweeks.co.uk/performance/gear-knobs/sparco-techno-gear-knob
That\'s the link for the gear knob.
Thank You.
C J R
If its a screw on version it needs to be 10mm thread for the standard FD OEM gearlever.
If its a slip on version located with grub screws, you need to enquire whether it comes with a plastic collar to centralise it on the grear stick.
Jot17
Ok thank young will find out.
Jot17
boosted
If its then grub screw version then it will be a pita as will work loose and come off in your hand when your changing gear! I have threadlocked my momo 1 as every couple of months would work loose and i could never find the tiny allen key todo it back up with Lol! :Giggle
Jot17
Quote from: boosted;831439If its then grub screw version then it will be a pita as will work loose and come off in your hand when your changing gear! I have threadlocked my momo 1 as every couple of months would work loose and i could never find the tiny allen key todo it back up with Lol! :Giggle
Lol, I hope it\'s the screw on one so i dont have the same problem, Ive emailed the so will find out soon. What do you mean by you\'ve thread locked it, sorry if it\'s a dumb question lol.
boosted
Loctite do a thread locking glue that stops the grubs screws coming undone! ..Its strong enough to stop coming undo but weak enough to undo with allen key in the future when you want to remove it !
(the blue stuff you find on threads when undo bolts associated with brakes).
Jot17
Quote from: boosted;831446Loctite do a thread locking glue that stops the grubs screws coming undone! ..Its strong enough to stop coming undo but weak enough to undo with allen key in the future when you want to remove it !
Oh ok, lol thanks.
