FD3S brake bleed valves
Started by SFW, July 21, 2012, 09:07:33 PM
SFW
I have just upgraded all the brake lines, discs and pads on my car.
i blead 3 corners ... all OK! then i came to the final one and sheered off the bleed valve :Grrr
does anyone know the correct size required and where i can get one at short notice?
cheers
davehg
any motor factors should have one, it wont be FD specific. i dont know the thread size though, may be best to remoce the broken bit and match it up
wolfie1
what to do is get someone inside the car and pump up the pressre say 5-6 times then hold the pedal down, then with the brake pedal depressed crack open the brake line on the caliper and you should be able to bleed it this way
SFW
Quote from: wolfie1;830051what to do is get someone inside the car and pump up the pressre say 5-6 times then hold the pedal down, then with the brake pedal depressed crack open the brake line on the caliper and you should be able to bleed it this way
that did the job..... thanks!
