porting
Started by billybobbooth, July 19, 2012, 09:00:19 PM
Will66
Porting is definitely a job for rebuild time, although you could certainly clean up manifolds and suchlike with them off the engine and may gain small improvements.
"Eat it with a chopstick!"
dthebuk
Quite a few guys over the pond run big power on stock ports and seem to do quite well. Does your engine really need porting?
:burnout
billybobbooth
I\'m doing a fd manifold mod and was going to port all the intakes to the gaskets. It was worth the question while the engine was out.
If I can fit the rebuild kit in then I\'ll do it but if not will have to just wait.
Cool thanks guys once again.
