Vacuum help
Started by Mikey22, June 13, 2012, 06:13:29 PM
Mikey22
ok my description may not be absolutely great but should there be a great amount of air coming out of the pipe between the induction kit and the engine block?
This is the metal extension i think which is the breather for the engine. Ive had the plenum off to replace the coil pack and swap two one way check valves over. Now when i run the car there is air blowing out of this pipe.
However i cant think of why.
Thanks for your help
Mikey22
Bump......sorry i really need help on this
boosted
Photo might be best idea as you\'ll give us a clue ( put a penny on leaky pipe or similar).....use photobucket or similar......any air leak on induction side not a good thing.
Mikey22
Ill take some photos tonight when i get home. Not sure what the hell it is. All i know is it\'s the metal pipe next to the top air intake. I have a pic now but its hidden behind the throttle cables so you cant see it. Its a similar size to the ones the dump (recirculating) valves have on the induction.
