Which wire for the horn?
Started by ChrisL, June 24, 2012, 11:53:10 AM
ChrisL
Hi guys, another one from me :2Confused
Im moving the horn control, to a small button on the dash, to keep Mr. MOT happy.
My question is, which wire behind the column is the horn? I\'ve found a suitable ground on top of the transmission tunnel. I dont want a wire wrapping all around the steering column though...
Re-test before Thursday, running out of time!! :rollin
Thanks all.
ChrisL
Never mind, found it lol.
For anyone\'s future reference, it\'s a green wire, with an orange stripe on it.
You\'ll need to take of the column plastics, gently prise off the top half, and four obvious screws on the bottom half. I didn\'t unclip the light for the ignition barrel, just be careful with it :)
The harness goes to the top left of the steering column, you can see the wire as it leaves the harness insulation, and connects to the column, to complete the circuit.
