Sunroof Drain pipes?
Started by Grizzly, April 08, 2012, 02:42:25 PM
Hi all.
I have a bit of a waterleak from the Sunroof in the FD and after having a good look at the seals etc i have come to the conclusion the drains must be blocked.
The Problem is i can\'t really see where the drain pipes fix to the Sunroof assembly and as i\'ve never had the head lining out of the car i\'m not sure how they route?
Can anyone help?
Will66
I\'ve had these blocked on previous cars.  The most simple way I got them clean was to poke a straightened out wire coat hanger down them.
"Eat it with a chopstick!"
Ricco_04
Could you find the other end and get an air line on it?
i had a look at a sunroof mech on e-bay and there seems to be a drain in each corner, problem is the drains seem to be under the runners and i poured some water into the side thats ok and it comes out at the base of the a piller which is covered by the wing..... so i think i may need to strip the head lining out :(
