Dragon performance pulley kit!!
Started by mattinsRX7, March 11, 2012, 08:55:52 PM
mattinsRX7
I purchased the new dragon performance pulley kit of eBay. It looks great buti have been told the water pump pulley slips at higher revs. I have seen loads of single turbo rx\'s with the similar setup so I wouldn\'t of thought it could be that much of a problem. Can anyone advise me? Should I go back to standard pulleys?
Aron
If you have removed the air pump you should run a twin alt pulley setup to avoid belt slippage, what does the pulley kit have in it?
mattinsRX7
Yeah I\'ve had a look at them idler pulleys from dm but there currently out of stock. My kit is just the rotor shaped alt pulley and water pump pulley which is a lot bigger than the stock one, which gives a lot more grip on the new belt.
Indian
fil_auto
Quote from: Indian;817172this will solve all your problems.. Works great for me:
http://www.reganrotaryracing.com/tweakit.htm
That looks beautifully made :)
I run a DM Motorsport version myself and that\' pretty awesome too :)
http://www.dm-motorsport.co.uk/billet-air-pump-idler-pulley-33-c.asp
Phil
