Rx7 Engine swap 93 Engine to a 1997 Chassis things I should know.
Started by unwindcompletely, January 27, 2012, 08:48:48 PM
rx7boy
Doing the same conversion myself.
You will need to swap the following
- engine loom from 97 engine onto 93 engine
- rats nest solenoids system from 97 to 93
Or you could use the ecu for the 93 car :)
Apart from that there were not really any more differences I\'m aware of yet :)
DM-Motorsport.co.uk
unwindcompletely
Thank you rx7boy!!!
nice one sounds ok then
I was thinking about using the 93 ECU as I will assume its set up for the engine. The rats nest has been removed. It’s not my car but if it was I think I would have run it stock and probably rebuild the engine as don’t really know of its past. It definitely runs and pulls like a train but I’m a bit anal and I’m of the belief that it’s better to do maintenance than fix!! but my mate just wants to do the swap. I will make him do a compression test and get it on a rolling rd to check how it’s running.:)  If we get it running lol :)
rx7boy
just be aware If you have removed rats nest you will need to be using a apexi otherwise the standard ecu will throw an error code and go into limp mode
DM-Motorsport.co.uk
oyvindjs
i believe you can jump the plugs in the rats nest(if removed) with resistors to avoid the error code.
RobMatthews
you may find the horseshoe loom around the front of the car different to,I have three,two from same year are even different, inc the plugs
parts supplied by;
DM-Motorsport.co.uk
Info@DM-Motorsport.co.uk
unwindcompletely
#6
Thanks rx7boy & oyvindjs
what do you think would be best use the 97 stock ECU or use the 93 ECU, what would you guys do?
I’m now tempted just to plug all the 97 sensors into the 93 engine if they fit which rx7boy has already said they will as this sounds like it will be plug and play, this would save a lot of time as there will be no need to sort the wiring out.
I think the Rats nest cabling has been jumped with resistors.
RobMatthews
yes I think this would be likely as the ECU connectors are different I would of assumed other things are also....
RobMatthews
have you got the engine loom from the 97 car?
If so I would be going with that, you would also benifit from the 16bit ecu then to
parts supplied by;
DM-Motorsport.co.uk
unwindcompletely
yes I believe we have the loom from the 97 can. i think that\'s what were going to do :)
The good:)
The Bad
The engine :P
RobMatthews
I have the same halfords tool kit, had it nearly 10 yrs now and never broken it, and i have abused it quite a bit to!
can I have your black headlight covers please-assuming they are in good condition and undamaged in the accident,and the litthe clip the bonnet stay clips into...
The black one dont look to bad have you twisted the shell?
parts supplied by;
DM-Motorsport.co.uk
unwindcompletely
RobMatthews :) these are not my cars but I\'m helping out a friend so will ask about the back headlight covers and get some pictures soon and send them to you!
as for the tool kit this is my m8s only tools well for this project a new engine crane has been purchased and other cool bits :)  if your after a good socket set I really recommend Crescent one of the best things I\'ve got!
http://www.ebay.co.uk/itm/CRESCENT-195-Pc-Pro-Mechanic-Tools-Spanners-Sockets-Set-/180642706642?pt=UK_Hand_Tools_Equipment&hash=item2a0f24f4d2
unwindcompletely
Robmatthews, it\'s the cars actual owner here :P the passenger rear light cover was smashed to s**t in the accident, the centre one (if I remember correctly) has a few chips, but the drivers side is fine which you are welcome too once the engine swap has been done :)
I\'m planning on breaking the remainder of the black car once I\'m finish so if you need anything else just shout :)
RobMatthews
Front headlight covers, not rears!
Whats your email I\'ll make you a list...save messing this thread up!
parts supplied by;
DM-Motorsport.co.uk
unwindcompletely
Ahhh right fronts ain\'t in the best of conditions :S
My email is sean_hyde90@yahoo.co.uk
I\'ll look forward to hearing from you :)
