diffrent afm
Started by billybobbooth, January 26, 2012, 09:20:45 AM
billybobbooth
hi guys is there any way of putting a less restrictive afm on to a 1990 rx7 fc turbo 2??
billybobbooth
e.g. putting a diffrent cars one on?
Prof is fitting a hotwire MAF to his at some point, how much extra power are you going for? You could always get an aftermarket ECU like I have and just remove the AFM completly using an AFM replacement map :rollin
billybobbooth
I will be putting a aftermarket ecu on later when i fit a big turbo. I just wanna try and get the car back on the road for the wedding.
Also my air filter is shot but i have a direct cold feed i had from my mr2 that i was going to use but it won\'t fit easly with the afm coz of its size.
Also it must make some difference fitting a bigger one as the size of it is so restrictive.
