bolt on arches
Started by rising son, January 05, 2012, 11:40:11 PM
billybobbooth
Im just going to get a wide front wings and rear then cut the rear arches out and put a new plate in that sit higher up to avoid wheel scrub then seal and pop rivet the rear arch on incase i need to remove later on for replacement and to get that race look. ( all undersealed behind the new rear arch.)
rising son
i done something similar with my s13.... dont fancy doing any cutting on a vert tho and taking some of the structure away..... or i wud have done the same
Kodiak
You could always try going Gundam style with huge overhanging arches, like thus:
http://noonefresher.files.wordpress.com/2011/02/bosozoku-style-rx7-fc-2.jpg
FC3S T2 in Red(-ish)
2yr old daughter sits in car, says "It\'s too loud daddy"  :flamed
rising son
front ones are the same as the ones on my 13... they rears wud need some uber wheels....
dthebuk
Unless you put a lot of time and effort in you won\'t get those JUN style arches looking good. I remember the car that flatouts arches came from being incredibly low (the exhuast was like an inch or so off the ground) with some absolutely badass wheels on it, but for some reason it looked silly high.
Tbh a stock bodied FC with wide front arches and rear over fenders is the way to go tbh. Extremely subtle, clean and at the same time mean :D
heres the car
:burnout
rising son
thinking am gonna possibly go for the vented wings and over fenders instead.... not keen on that front bumper ^^, rest of it looks good!
B.Martin
Yeah I like the bn style fronts you can get from epr, might need them if I decide to use rear  starion rims on the front as well. Let us know what path you chose and how you get on mate.
rising son
will do martin... im lucky enough to have found myself a near mint vert so wanna do somethin special with it.... not gonna be a quick job
