Magnecor ignition leads
Started by Efinity, May 26, 2010, 05:19:01 PM
StreetracerHCI
Quote from: gonzodave;784421My kv85 look exactly the same as your second picture :cool
:eek:  my seem too short to tell the truth, I will risk it will take 16 bits.
 if they are not going well sell it on the forum ahhahaah :spank
[SIGPIC]http://mazdarotaryclub.com/forums/signaturepics/sigpic18627_2.gif[/SIGPIC]
My FD3S From Rome, Forever work in progress :mmmm
gonzodave
I have just measured mine, if your measurments are from center of plugs then mine are the same. They are the 16bit import set which i got from mazda rotary parts.
StreetracerHCI
thx gonzo :D
ahhaha, I do not want to think of the work I have done to change 4 wires:Hammer
OMG :(
I want to die :Hammer
I have to find another solution, I will try with pliers after I disassembled the elbow :rollin
gonzodave
I am yet to do mine as they only arrived today, so i have all this fun to come :-)
StreetracerHCI
Hehehe
you will do the work alone?:guinness
gonzodave
Yep as long as my oil turns up tommorrow i will be changing plugs leads fuel filter and oil + filter saturday morning, never know some mates might turn up to watch me work ha ha
StreetracerHCI
maintenance kit arrived in only 4 days from uk.
:Thumbsup!
:InLove:3gears-lh
Black7Conv
I am about to order some Magnecor ignition leads, especialy 10mm, but i dont know if i could go with 8 bit or 16 bit ones..you see i have a 93 european fd3s rx7, but the engine, engine harness, under dash harness and ecu (apexi power fc) are of a late spec, 2000 model, so??
also, what is the difference between R-100 and KV85?
thanks in advance!
George
TII black Conv.
