Lambda to Air Fuel Ratio Table
Started by Glenn Butcher, October 30, 2003, 11:27:51 PM
Glenn Butcher
Hi all,
Thought I would post this up for reference, and stick the thread.  If you have anything to add - please do so.
Lambda to   Air Fuel Ratio Table:
Lambda
Air Fuel Ratio
PetrolAlcohol (Methanol)LPGDiesel
RICH         END OF SCALE
0.7010.34.510.910.2
0.7511.04.811.610.9
0.8011.85.112.411.6
0.8512.55.413.212.3
0.9013.25.814.013.1
0.9514.06.114.713.8
1.0014.76.415.514.5
1.0515.46.716.315.2
1.1016.27.017.116.0
1.1516.97.417.816.7
1.2017.67.718.617.4
1.2518.48.019.418.1
1.3019.18.320.218.9
1.3519.88.620.919.6
1.4020.69.021.720.3
1.4521.39.322.521.0
1.5022.19.623.321.8
1.5522.89.924.022.5
LEAN         END OF SCALE
1.6023.510.224.823.2
Thanks,
bill shurvinton
Please define \'alcohol\' Methanol and ethanol have different stoich AFRs
Glenn Butcher
Hmmm, it was from a table I was sent on fax - I\'ll find out Bill.  Actually I may add the two.
Thanks,
bill shurvinton
I have the figures at home so I\'ll post them tonight.
Glenn Butcher
Ta mate - I\'ve been looking around for them but cannot find at the moment.
Thanks,
Carl
Hi Glenn and Bill,
The alcohol in this case is fior Methanol.
If it was nitromethane then it would be 3to1 ratio of fuel to air for Stoichiometric and Methanol is around 7 to 1.
Kind regards
Carl
Glenn Butcher
Thanks Carl,  I literally just got the answer back also.  :)
Thanks,
bill shurvinton
Couldn\'t extract the FJO table from pdf to post a double check, but examining them there is at worst a 0.2 difference.
I have a minor problem with this table thinking more about it.
Basically a wideband will measure stoich for any fuel no problems.
However once you are rich or lean of stoich you are measuring a different set of combustion products so a simple linear shift like this WILL give the wrong answer.
Bill
P.S. Stoich for ethanol is 9:1. Worth pointing out that ethanol is a whole lot cheaper and more readily available in this country.
Neat toluene on the other hand......:-)
yonner
what ratio do you want in a fast street car????? im guesing 9:1 coz i read thats waht the stock is
when your life is a mess light one more ciggaret its so logical!
