front shock bottom bush
Started by merlin2002, November 11, 2011, 07:39:10 PM
merlin2002
Anyone know where I can but front shock lower bushes from?
Rob
merlin2002
well you can use POWERFLEX 100 Series Top-Hat Bush (PF99-104)
for Tien Coilovers one pack of 2 top hats will do you both sides...
you have to remove all rubber from insert on the shock bu not the outer shell, you will then need to have made up a sleeve 49mm long 12mm id and 18mm od then press all togeather job done
Rob
