rear window/windscreen rubber
Started by winterov78, August 18, 2011, 01:14:41 AM
winterov78
Guys,
The rear window/screen exterior rubber which goes all around the glass is in a bad way on my car. Its lifting up here and there and is quite perished so i was going to go around it with a gun and black sealant to get it all back down and tight but think it might become a botch job very easily.. Recently i saw an rx7 with older than mine with an immaculate and wider rubber fitting perfectly.
Can you go to someone who makes these to fit your rear window perfectly and if so does anyone know a place or have had it done?
thanks for any info
peter
Speedline Imports
Hi Peter,
You can buy a genuine one direct from Mazda but expect to pay over £80 from memory.  Best bet is to take your car to windscreen specialist and see if they have a trim that is the same/similar.
Regards,
Martin
martin@speedlineimports.co.uk
TEL. 07742 690672
Monday-Friday 9am-5pm
Speedline on Facebook
AtomicRex
I would recommend you using the genuine one. Ive tried after market versions and they peal off and leak!
They arent cheap....but I always carry a front and rear in stock
Mark Ide
Hi, how easy is it to fit a new one?
Mark
AtomicRex
Not something I would recommend doing yourself.  I have a local windscreen fitter I use.
SiH
Isn\'t it the rear that something like a Transit rubber fits?
Mark Ide
Thanks... I thought that you might say that!
Regards
Mark
Speedline Imports
Quote from: SiH;783795Isn\'t it the rear that something like a Transit rubber fits?
Think its the Mondeo one Si, Like I said, worth trying a windcreen place first and get a price before pulling your trousers down and getting a Mazda one!
TEL. 07742 690672
Eoiny555
I just took mine off when i was repainting the boot lid, mines in good condition so i am just going to run a bead of black silicone in the groove & put it back on
