Tornado 5.45m RIB
Started by Timmyc, January 14, 2013, 11:29:36 PM
Timmyc
Hey guys, as we havent had the time to use her much its about time we sold our RIB, it has been a joy to own and use, great in rough seas and fine weather alike, no photos on photobucket yet so ask and i will arrange photos
price: 10,000 gbp ovno
Tornado 5.45m RIB
Craft:
Length 5.45 m with a 2.0m Beam
Inflation chambers x5
Over pressure relief valves x 5
150mm profiled rubbing strake
External life lines
Anti slip GRP Deck finish
Raised bow stowage locker with access hatch
Rear drain well with drain trunk draining system
Hull:
Towing "U" Bolts
Bow eye c/w painter
Tubes:
Additional protection over tubes
Internal life lines on straight of tube
Paddles and holders
Hypalon Fabric
Console:
Single console c/w/ windscreen with stainless steel surround
Stainless steel battery holder under driver’s seat
Side access hatches on seat
Upholstered seat with stainless steel back support
Side access hatch to fuel tank
Seating:
3 x seats in delta formation c/w back support
Under seat storage
Steering System:
Bay Star hydraulic steering including helm pump, engine ram and hoses.
Fuel system:
Integral Aluminium fuel tank, ISO rated fuel line,
Quicksilver fuel filter
Illuminated Console mounted fuel gauge
Sender unit
A Frame
Heavy duty tubular Stainless Steel double A frame
Life buoys and mounting brackets
Life buoy light with line and holder
Stainless Steel Square dry tub holders x 2
Engine:
Mariner 90HP ELPT Four Stroke outboard motor with power trim and tilt
Mercury control
Electric start, Vengeance 19p Stainless prop,
Illuminated console mounted Tacho
Engine securing lock
Single 12v battery
Vessel name and decals on engine
Aqua signal series 25 Navigation lights Port, Starboard and Top White
Stainless steel Navigation light mounting brackets
Whale 9000 manual bilge pump switched from console
Rule 1100 automatic bilge pump
Plastimo back lit console mounted compass
Waterproof fuse box
Electronics:
Icom M503 VHF marine radio (with new spare set)
Raymarine 65 colour plotter with multi function display
Garmin GPS / Fish finder
Additional equipment:
20lb CQR galvanised anchor with chain and 12mm nylon rope
Telescopic boat hook
6 off self inflating 150N life Jackets
Radar reflector fitted to top of "A" Frame
Selection of rope
Inshore flare pack
Dry tub
Fenders
Console cover
Engine cover
Prop bag
Trailer:
Snipe 2000S80 break back trailer
Balloon tyre quick fit wheel assembly (ideal for beach launching)
Trailer lighting board
Manual winch with winch strap
