mental RX3 20B in Jamaica
Started by goldk28611, September 09, 2011, 04:14:25 PM
goldk28611
Sounds awesome! :eek:
It\'s a RX3 - can\'t edit title - Mods?
yehreally
Grant Monkhouse
That\'s the old version. He\'s now sponsored by rockstar energy drink, car is lower wider but just as loud and full of awesomeness
re japi
That thing is awesome! He should name it Spitfire. Did you notice in top right corner those flames :) (reflection ofthem)
TiddlesRX7
yehreally
goldk28611
Quote from: re japi;787547That thing is awesome! He should name it Spitfire. Did you notice in top right corner those flames :) (reflection ofthem)
Yeah I saw that too - need to find an outside video of in on the track now!
BRB :WaveBye
hayden
There\'s plenty about. Do a search. I believe this car was built in New Zealand using an RX-8 as a base.
goldk28611
found a video with a combination of in and out of car shots
Grant Monkhouse
Quote from: hayden;787910There\'s plenty about. Do a search. I believe this car was built in New Zealand using an RX-8 as a base.
If they did there won\'t he much if it left considering how much shorter the wheel base is of an rx3 compared to an 8. Also the height and width of the car are different
goldk28611
Quote from: Grant Monkhouse;787924If they did there won\'t he much if it left considering how much shorter the wheel base is of an rx3 compared to an 8. Also the height and width of the car are different
...it uses RX8 suspension
Source L I N K
