PPC £999 challenge
Started by MrHanky, July 14, 2011, 11:10:39 AM
Brett
It was about 8 years ago, but yeah :p
Brap Brap Brap Brap
RotorHeid
Quote from: johnm;776134Don\'t waste your time and money taking out the fuel injection.  Just remove the stock air filter.  On the exhaust remove the thermal brick and the remainder of the stock exhaust.  Find a second hand racing beat exhaust or similar.
The stock ecu will learn the new set-up, but you need to run it on a dyno.  This set-up in a dax rush gave 165 bhp at the wheels.  The first run on the dyno gave 120 bhp, by the third run (nothing else changed) i had 165 bhp.
As others have said get rid of weight and increase suspension control.
fit\'lik john, totally quite agreed with you there to save money.
 think that you mean 165@fly not wheel on injection.
delly carb can do 165 at wheels..(180+hp@fly)
B.Martin
You really need to \'carb it up\' man, if you can get it within your budget that\'s the way to go!!
MrHanky
Quote from: B.Martin;776507You really need to \'carb it up\' man, if you can get it within your budget that\'s the way to go!!
Getting it within budget is going to be the issue. Keeping an eye out for a 48 Ida on the US and Aus sites
TiddlesRX7
Thought this rung a bell. Not sure if you\'ve seen this before but have a look.
http://www.mazdarotaryclub.com/forums/showthread.php?t=47355
Ade
