Rebuild....How hard?
Started by Mikey22, July 09, 2011, 07:54:54 PM
Mikey22
ok i know this is a little off topic but i have to ask as cant find anything in the search or FAQ\'s.
I think im being a lil retarded here but how do you upload pics? lol
jamison1982
link from photobucket mate
- Fezcat -
use the [img] [ /img]
Code from photobucket :)
Mikey22
jamison1982
Quote from: - Fezcat -;775280http://lmgtfy.com/?q=photobucket
thats awsome lol
Quote from: - Fezcat -;775247What engine stand would you reccommend?
The engines quite light, so most engine stands will cope with the weight - you want one that allows you to lock the engine off at different rotations, and you\'ll need an adaptor plate as Mitch said - that bolts to the front housing and then has 4 slots that allow any standard engine stand to bolt up.  The engine stand must be capable of allowing the front iron to be placed horizontally.
You can see the adaptor in use with a cheapish Sealy engine stand :)
http://www.mazdarotaryclub.com/forums/attachment.php?attachmentid=46417&d=1267794587
(Picture from my engine rebuild thread)
RotorHeid
mikey22, can you wait until I returned from abroad.
look at your own country man, that\'s me( 3 hoor drive frae yoor hoose) and I can do for you but will cost you few pounds to do it right with my experice(sp) from basic build to race proved engines
don\'t carried your engine around the uk,looking for a adviced,video etccc.
it\'ll take you long to rebuild yourself with your bar- zero experice(sp).
you\'ll learn as you go like me from 20+years knowelge from know nothing to easy to rebuild today, that\'s experice(sp)knowelge and put it right at first time..
you must removed your engine and sent it to me if you like and I\'ll stripped it down along full inspection, cleaning, reconidion apex seals/rotorhousing if reqiured and rebuild it back.
I\'m not putting pressure on you as it\'s a free country and you can think whatever you want which to suit you.
good luck and sorry,my engklish\'s crap.
ssn11
i made one when i did my rebuild, used a plate of 6mm steel drilled some holes job done.
sean
