couple of \'where do they go\' questions.
Started by RobMatthews, June 17, 2011, 12:29:16 PM
RobMatthews
Guys im working on a car im putting back to standard(ish).
I have a couple of questions which i think i have answered myself but an answer from someone in the know be better please :-)
First one is the turbo actuators, in the pic comming off the l/h nipple on each one should they go to a a couple of nipples behind the actuators on the pipe off the turbo?like the red lines?
[ATTACH]52361[/ATTACH]
Pipe coming from under the uim was going to the double throttle control? which was removed by the previous owner so blanked off no longer required?
[ATTACH]52363[/ATTACH]
The throttle warm up has been removed and thats what these pipes would have done so are now redundent?, with the bottom pipe emerging behing the alternator under the black vac box? and no longer used?
[ATTACH]52362[/ATTACH]
thanks rob
parts supplied by;
DM-Motorsport.co.uk
Info@DM-Motorsport.co.uk
