Injectors,Fuel Rail
Started by John RX7, May 31, 2011, 08:35:03 AM
John RX7
Hey,
I\'m aiming for about 340-350 bhp on my standard twins for my FD3S rx7,im i correct in thinking that the standard injectors will max out and i will need to upgrade,also the fuel rail can anybody shed any light on this
John
brundish24
I think that 350 is the max on twins and you will need to upgrade the fuel rail you can put in a full set of 850s I believe or add 1680s the fuel pump will need to be upgraded too and ofcouse a remap.
RXSpeedy
850\'s all around but you will need you primary rail machined to allow the 850\'s to fit correctly. Or you can just get a secondary rail with 1680\'s and leave the 550\'s which is from what ive heard easier to map for idle. I\'d get a Bosch 044 just for piece of mind as well.
John RX7
where would I get the primary rail machined,do i have to take it of the LIMwould it be 4 850 injectors?ok change fuel pump
RXSpeedy
Any machine shop can do the job with the correct machinery. http://www.mazdarotaryclub.com/forums/showthread.php?t=65332&highlight=850
The primary rail is on the block the secondary rail is on the lim so that can stay in place. yeh 4 850 injectors all around.
