water coolant
Started by hotstepper1973, July 04, 2004, 04:32:13 PM
hotstepper1973
does anyone know how to bleed air off the water system as i think you are supposed to bleed the system when you top the water up. I am not sure but am i right in thinking that there is a bleeding pipe for the water just behind the plenum which then releases the air thus then preventing air locks in the water system, that is all i know so any help words or diagrams would be grateful.
You only get one life live it
gsb876
Hi John is it a stock rad you have?
I had a modded rad that when you bled the system you just topped up realeased a nut at the top of the rad and then start the car up and out come the bubbles, if its a stock rad then no idea?
Sorry chap, :(  you still chuffed with your 1/4 mile run at rotorstock?
hotstepper1973
yes gurj it is a stock rad so thanks anyway for your help. And yes i am still very pleased with my time at rotorstock.
gsb876
Sorry couldn\'t help John:(
Shaq
i removed that pipe that is attached to the plenum when i was topping up. here is some info
http://www.scuderiaciriani.com/rx7/how-to_cooling_system.html
i followed this one :
http://www.rx7.org/Robinette/flush.htm
if you have any probs. let me know.
shaQ
