that it i have had it with the boost problem
Started by lotuscorsa, August 24, 2010, 03:38:30 PM
Clarky
Had the same problem, changed the check valve under the pressure tank as you say, and all fixed.
Quote from: neil_jdmr;712974If you are still on the standard ecu its very likely boost creep and you ecu retarding the timing, i had the same problem till i switched to a pfc. If your already on a pfc then ill go with a check valve probably the one under the pressure tank.
Lead me not into temptation, I can find it myself...
But i can always do with some help now due to, my advancing years!
stronzen
which pressure tank do you mean ? where is that one located :-) ?
neil_jdmr
Its just in front of the uim and behind the alternator
