headlights wont work on fd
Started by stronzen, May 03, 2011, 08:30:01 AM
stronzen
hi guys,
for some reason my headlights (low beam) wont work
retras will go up when i push the button, but wont do so when i turn on low beam (no light either)
however when pulling for high beam, they do go up and light up no problem
so i guessed it must be some fuse or relay and i checked those.
all fuses in the engine bay seem ok... same for the relays.
however when i checked for voltage in the fusebox (marked in pic)
the voltmeter showed 0 !
any clues ?
are there any more fuses/relays related to the headlights in the interior ?
many thanks
stronzen
just checked for voltage again and it did show 12V at the fuse box... so thats sorted (must have been my mistake)
skybusr34
just had this prob.. in the pic above. just to the right of the next big fuse box over wheel arch.. there is a rubber coated relay. thats the one thats most likely to be messed up.. mine took apart. wd40 over night. dried it out .. perfect
stronzen
could you post a pic of the one you mean ?
stronzen
replaced the relay you were talking about ... guess what !? working now  :-) !!! thanks alot buddy
