compression test on my new RX7
Started by merlin2002, May 02, 2011, 06:11:37 PM
merlin2002
Hi guys just wanted to get some opinions on my engine compression test I carried out today before I start spending lots of money on it.
She starts and runs fine, but Rich (plugs are black afer 10 miles on new ones, in comparison to my mates rx running a power fc which are no way black at all!!)
Ive done 2 vids one front and one for rear bank, any comments or opinions would be great.
The tests were carried out on a COLD engine not run for 24 hours
http://www.youtube.com/watch?v=4YPI_s_VMxA
http://www.youtube.com/watch?v=qoB6BDRaYRI
Rob
FD3S Efini
Hi mate that looks like good figures if its around the 8 mark, how many miles has the engine got on it?
Also a power FC if mapped correctly will certainly lower the chance of the plugs getting black due to running rich,
Kris
merlin2002
what are peoples opinions on apexi safc till money allows a power fc?
miles is around 50-60k
was imported in 2006 with these results
front
         7.75
         7.65
         7.15
rear
         7.35
         7.35
         7.50
its done around 10k since then, but i dont know if that was a cold or hot test!
Rob
1 face is a bit less even on the front, if those were the 2006 results it might be an idea to just get the compression test redone with a Mazda tester, I believe a forum member has one and is doing tests at a much cheaper rate than main dealer, would give you peace of mind as then you will know the compression test was carried out correctly and at the right RPMs etc
