lol the first prob.....
Started by cmnck06, April 07, 2011, 08:11:36 PM
cmnck06
before av even begun ..the battery in the cars is flat . as i connected it anyway i noticed the siselights are stayin on even though they are switched off. any one any ideas?itchin to get it on the road..
myatt1972
Are the lights on even if the ignition is turned off ?
My old B reg had the side lights on whenever the ignition was on a bit like the Volvo day running lights, to turn them off there is a connector on the back of the little cubby hole above the clock. Pull the cubby hole out and disconnect the connector.
Keith...
cmnck06
#2
:Thumbs-upoutstandin , yip as described.the lights are on even on when the keys out the ignition. i will do as you say mate and let you know ..cheers chris:D
CHC (RIP)
Do the rear lights stay on too?
Could it be that the stalk switch needs cleaning or worst case replacing?
Cliff
1983 1st Gen Series 2 Elford Turbo - the New \'JAZ\'
Departed this world on July 19th 2019
Sadly Missed
cmnck06
yes the rear lights are on too..mnnn bugger
CHC (RIP)
Sounds like the light stalk/switch or a relay to me.
Sadly Missed
David Nock (RIP)
And to me. Does the switch feel right, nice and clicky when you twist it?
Sadly Missed
cmnck06
sprayed the switch with wd40, but i noticed theres a parking light switch on top off the cowling with 3 stages and bingo the lights went off . pmsl
CHC (RIP)
Quote from: cmnck06;756387sprayed the switch with wd40, but i noticed theres a parking light switch on top off the cowling with 3 stages and bingo the lights went off . pmsl
Sounds like an aftermarket modification to me - some pics would be good :mmmm
Sadly Missed
