bearing inside end of eccentric shaft??
Started by snyperboi, March 31, 2011, 07:01:03 PM
snyperboi
hi i am looking for the roller bearing located in the end of the eccentric shaft (bell housing/clutch side) i cannot find it anywhere and was wondering if someone could help me?
TRIND-FD
V8 fd\'s rock :cool
Pilot bearing - that\'s what to ask for :)
bumpstart
#3
DP
your auto timeout log out is too short in period and is annoying
bumpstart
the correct term is clutch spigot bearing
 quoting for pilot bearing will often get you the bearings for the alternator
bearing-
mazda = N326-11-D03
koyo = W0133-1640319
there is also a seal you order separate and its often forgotten
 forgetting it contributes to an early fail as the grease lube cannot be kept at the bearing
seal -
mazda =1881-11-404
beck arnley = 052-3471
Good point.  But when I order from my supplier he always knows I mean the bearing on the end of the eccentric shaft and includes the seal - as you say often forgotten.
It\'s strange but many clutch kits come with the bearing but not the seal.
kev-yorks
Quote from: bumpstart;753423DP
When you log in tick the check box remember me there is no time out that way and you can spend as long as you want composing posts.:Typing
Regards Kevin
