clutch alignment tool
Started by monterx7, January 21, 2011, 12:40:24 PM
monterx7
anyone know where i can score a clutch alignment tool this weekend?  just realized i got everything except for that piece:Hammer
any help will be greatly appreciated
thanks
88 gxlt US spec
86 egi UK spec
I got a universal one from CAF (Camberley Auto Factors) - not sure if they\'ve a branch near you?
At a pinch, and this worked for me before buying a tool for it, I\'ve used a socket that just fits in the splines and another that just fits in the spigot hole, you can wrap some tape around and lube with grease to get a \'snug\' but sliding fit. It\'s only to hold it whilst you do up the cover bolts.
They generally chuck a plastic tool in with a lot of kits, that works fine too.
monterx7
thanks for that.  looked up their shops and none around me
88 gxlt US spec
86 egi UK spec
davehg
any car parts auto place will sell a cheep draper one that will do the job. even halfords should stock it
monterx7
88 gxlt US spec
86 egi UK spec
David Nock (RIP)
An old method, maybe a last resort if you can\'t find a proper tool.
Cut a sweeping brush handle into a foot long dowel and whittle the end to fit into the release bearing. Then hammer the \'New Artifact\' into the old clutch plate spines. A bit of wax candle to ease it all and \'hey presto\' a perfect alignment tool for the new plate. I\'m 35,000 miles past the last time I did this.....no judder or problems.
Sadly Missed
SiH
First time I fitted the box a rather experienced local hero used an old gearbox input shaft he\'\'d sheared as ana lignment tool - took me fricking yonks to get the box on.
Next time I use a broom handle and smashed it in.
Box went on first time...
adib
what car are you doing fd , fc , or other
monterx7
88 gxlt US spec
86 egi UK spec
Indian
hmm darn.. I know the  fd can use the Mitsubishi Lancer EVO VIII & IX alignment tool.
it clutch number is ACT-AT03.
Im almost sure that the fc gen II uses the same alignment too.
