wheel spacers
Started by scottyboy, April 15, 2011, 04:15:50 PM
scottyboy
I want to get some wheel spacers to push them out but don\'t know what size spacers, what\'s the limit I can go dont mind if I need to roll the arches
F 18x8j et42 235x40
R 18x10j et 52 275x35
SiH
Could probably get away with 15\'s on the front without touching the arches, depending on alignment.
With just a tight lip roll, you could probably run a 20mm on the rear. With a flare, then you could probably get another 15mm or so out of it.
That\'s just a guide though - a lot depends on ride height and alignment.
I do like pokey wheels though, so if you want a slightly more conservative look, take 10mm off that.
sco77_8oy
Thanks Sih
would a Et22 offset with 10j 275x35x18 with just a lip roll be ok or ET27
SiH
There\'s no way you\'d pull off a 275 on an et22 with just a roll onfortunately :( Should be ble to fit it with a flare though :) I\'d say et27 would be pushing it too tbh.
